Lab not working: IR1101 - Industrial Routing and Edge Compute
jubor
The following lab has a malfunctioning IR1101. While after the lab has finished setting up, the environment shows "Active (with error)". Moreover, the IR 1101 shows to not be properly started.
5 Replies 5
@jubor cancel the reservation and start a new/fresh one - this normally clears the error for me.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
jubor
Thanks for the response. I have already cancelled the lab 3 times in total. Unfortunately, the problems reoccurs.
Might be an issue in the back end then, engineering team would need to look further.
I will close my 3rd reservation today and will try tomorrow.
jubor
Is this topic getting addressed by a Cisco engineer? Or is the lab just gonna stay faulty for the foreseeable future?
