04-15-2020 04:30 AM
i tried to get a reservation of this Labs.
Unfortunately these two errors appear at the Setup Process after the reservation:
Error: Script runner exited with exit code: 1
Description: Setting up Meraki Instance
Username: Patrick.Urlberger@sws.de
Email: Patrick.Urlberger@sws.de
GET calling: https://api.meraki.com/api/v0/organizations/549236/networks
https://api.meraki.com/api/v0/organizations/549236/networks called successfully
GET calling: https://api.meraki.com/api/v0/organizations/549236/admins
https://api.meraki.com/api/v0/organizations/549236/admins called successfully
No meraki networks available
Parameters:
Error: Resource Command Error
Description: Meraki Python Script Failed
Parameters:
The Lab is then Active(with error) and i don't get an e-Mail with the CiscoAnyConnect Credentials to connect.
Screenshots of the broken Lab are attached here.
Solved! Go to Solution.
04-15-2020 07:55 AM
04-15-2020 05:37 AM - edited 04-15-2020 09:16 AM
I'm also experiencing the same issue with both labs.
04-15-2020 07:55 AM
04-15-2020 09:06 AM
04-15-2020 09:17 AM
08-20-2020 01:36 AM
08-20-2020 03:19 AM
Sorry for your inconvenience. And we've just fixed the Meraki sandbox.
08-20-2020 04:15 AM
Working again. Thank you very much.
08-19-2020 03:20 AM - edited 08-19-2020 03:21 AM
Today wanted to setup the Meraki Small Business Lab and got this error as well, so seems to be an issue again see output:
08:36:45 Environment Driver Setup has begun
Setting up Meraki InstaceUsername: <USERNAME_HIDDEN>
Email: <EMAIL_HIDDEN> 08:37:15
Meraki Setup has Failed.
Please contact support at https://communities.cisco.com/community/developer/sandbox
08:37:18 Driver Complete.
'setup_meraki' resource command on 'Meraki-001' failed with 'Script runner exited with exit code: 1' error
Error: Script runner exited with exit code: 1 Description: https://api.meraki.com/api/v0/organizations/549236/networks GET calling: https://api.meraki.com/api/v0/organizations/549236/networks https://api.meraki.com/api/v0/organizations/549236/networks called successfully GET calling: https://api.meraki.com/api/v0/organizations/549236/admins https://api.meraki.com/api/v0/organizations/549236/admins called successfully No meraki networks available Parameters:
07-13-2021 09:11 PM
I'm working through Chapter 8 in the book DEVASC 200-901. The Meraki sandbox returns 404 for the URL and API key listed in the book pages 184,185: https://api.meraki.com/api/v0/organizations. This seems to be the same problems listed earlier in this thread.
