cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Configuring ASA Basic Settings and Firewall Using CLI
2309178
Hello, I was doing a job with the basic configuration of an ASA, however it does not pass 97%, does anyone know how to fix it?
The name of the activity is Configuring ASA Basic Settings and Firewall Using CLI and I attach a picture of the error.Screenshot 2024-04-13 164020.png
4 RESPUESTAS 4
balaji.bandi
what version of ASA code running on the device, what model ?  is this on ASDM (then what version)
where is that screenshot come from - not that i have come across ?
even old version should work as example below :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa84/configuration/guide/asa_84_cli_config/basic_dhcp.html
suggest to try latest version.
BB
can I see
show run
why DHCP is not work ?
MHM
I partially solved it but thank you.
you are so welcome
MHM
