cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
MAC-FLAPPING
saulcastillo505
HOLA.
Hace días me aparece varios mensajes en mi switch principal, sobre la VLAN 200 que es una VLAN la cual ocupamos como DHCP en los Access Point que se tienen instalados en varios sitios de mi lugar de trabajo.
454254: Jan 25 12:14:30.774 mex: %SW_MATM-4-MACFLAP_NOTIF: Host 9a8c.4334.9265 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454255: Jan 25 12:14:31.311 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b0f.2486 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454256: Jan 25 12:14:31.579 mex: %SW_MATM-4-MACFLAP_NOTIF: Host f07b.cba1.7448 in vlan 200 is flapping between port Gi0/2 and port Gi0/9
454257: Jan 25 12:14:34.641 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b14.fd6b in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454258: Jan 25 12:14:34.742 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b14.1f86 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454259: Jan 25 12:14:34.775 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b0f.06a4 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454260: Jan 25 12:14:36.151 mex: %SW_MATM-4-MACFLAP_NOTIF: Host 1498.776a.dd41 in vlan 200 is flapping between port Gi0/2 and port Gi0/6
454261: Jan 25 12:14:37.997 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b0f.2486 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454262: Jan 25 12:14:39.020 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b0f.06a4 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
454263: Jan 25 12:14:39.632 mex: %SW_MATM-4-MACFLAP_NOTIF: Host c8b2.9b14.a343 in vlan 200 is flapping between port Gi0/2 and port Gi0/10
Los puertos que se mencionan en los mensajes son puras troncales de otros switches dentro de la instalación.
Si alguien me podría decir como arreglar el problema, si es problema, o como quitar los mensajes.
Gracias y saludos a todos!
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hola,
Gracias por los comentarios, voy a probar a ver que sucede. Saludos !
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
gtrejoor
Hola saulcastillo505
Gracias por tú pregunta.
En este caso por lo que mencionas es por el Roaming de los Wireless devices,  esto es muy común porque el usuario esta en movimiento y esta conectandose a un AP-1 el switch guarda la MAC por 5 min por default y cuando se mueve a otro AP-2, el switch dice la MAC la aprendi por otro puerto y entonces manda ese aviso de que esta la misma MAC en dos puertos diferentes o en este caso dos APs diferentes.
Existe un workaround es que es reducir el tiempo que pasa la MAC address en la MAC table antes de hacerle un refresh.
config t
mac address-table aging-time # (# tiempo en segundos) vlan # (# vlan donde tienes el MAC flapp)
end
Este timer no se sugiere tan agresivo porque podrias causar consumo de CPU pero puedes probar con un valor más bajo como por ejemplo 3 min.
Esto no resolvera el MAC flapping, solo reducira el número de estos. Si quieres una solución permanente es necesario tener una controladora de Wireless (WLC), ya que esta evita mandar estos anuncios a tu switch y maneja todos esos movimientos locales.
Referencias
https://www.oreilly.com/library/view/cisco-ios-in/0596008694/re550.html
https://community.cisco.com/t5/wireless/mac-flaps-from-wireless-network/td-p/2300795
https://community.cisco.com/t5/wireless/mac-flapping-between-two-ap-access-point-in-wlc-wireless-lan/td-p/3852773
Saludos,
Hola,
Hola @saulcastillo505
En realidad no es un error, solo es una notificación
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Hilda Arteaga
hola @Daniel Ordóñez Flores y @gtrejoor muchas gracias a ambos por sus aportaciones
Esperamos la información sea de ayuda @saulcastillo505
