cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
8
Respuestas
NIM Card module ISR 4400 license
inteldarvid
Hello All,
I wasn't able to find a Hardware category to post this in, so hopefully this is ok...
I have a question, could you help me please, Is a license necessary to expand the NIM modules on an ISR4400 router? Because I want to add more NIM modules to the router.
Thank you
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
@inteldarvid
You will nred performance license.
See Table 6
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
And that:
Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
Best regards
Ver la solución en mensaje original publicado
8 RESPUESTAS 8
M02@rt37
Hello @inteldarvid
No license is necessary to add NIM module on ISR4400.
Best regards
balaji.bandi
its all depends on what NIM Card module you installing, if this is L2 module you do not need any License,
if any WAN Module  (some may required performance License to more bandwidth).
BB
Dear , in this case the Gigabit L3 modules to increase bandwidth. How can I find, if that type of performance licensing is necessary on the router? Thank you
@inteldarvid
See Table 6
And that:
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
Best regards
Thank you very much dear, thank you very much to everyone who dedicated their time to helping me with my question.
Have a good week
You're so Welcome @inteldarvid
Best regards
No worries, since some routers come with default throughput, if you need to go beyond you need performance License to break that barrier, most of the datasheet that information for you along with some modules.
BB
you need to provide the module specification or refer the datasheet provided by other poster
BB
