ISR 4000 Boost License vs. Performance License
mbroberson1
Level 3
Level 3
Hi Community,
Have a question for anyone with experience in the area of Boost and Performance Licenses.
In researching the Boost License, it seems this is the way to go to unlock (un-cap) the routers full throughout potential. Are there any circumstances when one would prefer the Performance License over the Boost License? The boost license seems obvious and the sure way to go.
Brandon
13 Replies 13
the performance license is a whole lot cheaper (around $1,200) than the boost license (around $2,500). It all depends on what bandwidth you need...
If cost is not a factor in decision, you would always go with Boost over Performance license... correct?
Boost gives you unlimited bandwidth and line rate so yes, if cost is not an issue, you would definitely go with boost...
One quick feedback as to why someone would use the Performance Lic vs Boost. Boost re-purposes service cores on some ISR4000 platforms. This means there MAY not be cores on the router to support container based applications. So if you wish to support container based applications along with performance improvement - you MAY use Perf vs Boost. Select models maybe impacted by the above point
Can someone advise and give me a template config of Cisco 6800. I am redesigning two core Switches for 15,000 users.
Your help is greatly appreciated.
Patrick
what are you looking for, that is, what does your topology look like ? Below is a link to general software configuration guides...
https://www.cisco.com/c/en/us/support/switches/catalyst-6800-series-switches/products-installation-and-configuration-guides-list.html
Old thread but hope below helps to anyone who comes to see this page in future.
Source - https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html#OrderingInformation
ISR 4000 Performance on Demand license
Common for the new 4000 Family is that all platforms come with fixed maximum performance levels. One fixed base performance level is delivered as factory default with an optional performance-on-demand license to increase the base forwarding throughput. This scenario enables deployment in high-speed WAN environments through performance-on-demand licensing to double or, for one of the platforms, triple the router capacity without any hardware upgrades.
All 4000 platforms have their fixed performance levels set well within actual capacity, with the result that performance does not necessarily degrade when a service is added to the configuration. This setup provides a deterministic performance, eliminating a network administrator’s guesswork when planning for new services.
For a more detailed document on ISR 4000 Series Performance and Platform Scalability, please refer to the Performance Whitepaper at https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/white-paper-c11-734550.html
In addition to the Performance License, customers may now order a Booster (or Boost) License that allows the router to perform between five or more times than that of the throughput with Performance License. In contrast to the deterministic performance described above, in the Booster mode, the router does not provide the deterministic level of performance as provided when operating with the default license or with the Performance license.
The Boost License provides a license tier above the Performance License allowing customers to completely remove the ISR4000’s performance limiters. This will make the ISR 4000 platforms perform at entirely new performance levels, allowing for 4+ Gbps of IP Routing (CEF) performance on the 4400 series ISRs. For deployments using encryption, IPSec throughput with AES 256 increases to 250Mbps on the lowest platform up to 10Gbps on the ISR4461.
Table 4.             Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
How much maximum BW can the router C4221 supports, including the boost license( total throughput) ? Thanks.
The Max CEF Bandwidth that 4221 can support is (approx) 1Gbps with Boost
For the ISR4221 with the boost license, the aggregate CEF Only Throughput will be 1.2 Gbps
As per the datasheet, the Boost lic will increase the capacity of the onboard Gigabit Ethernet Interfaces or do we need to add some SM to support the higher throughput?
There no change to interface performance.
What the Boost license actually does is remove the aggregate throughput shaper.  I.e. with a Basic or Performance license, the throughput, for the router as a whole, is artificially limited/capped.
