cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Alarm on firepower 2110
Electronic20
Hi Community,
I have 2 firepower in HA model 2110, and it has the following alerts, what does it mean and what could I execute to make these alerts disappear?
Another issue, once a FW failed, a change was made and it seems to me that when the HA was replaced they only placed the active IP and not the Standby, how could I place the standby IP?
2 RESPUESTAS 2
balaji.bandi
that indicated those interface not seeing any traffic, so check the VLAN tagged on the switch or SVI any issue ?
Since you mentioned this was happening after replacing the FW failed one - which one you replace standby or active one ?
if you replaced active one this might have failed over to standby, try failover back and check (if that fix the issue ?)
or this may be errors were there before ?
BB
Hi @balaji.bandi
It was validated that the ports mentioned and the vlan have traffic, I don't know why those alarms appear.
We just realized it a few days ago.
The Standby was replaced.
In any case, how can I eliminate these alarms? and put IP to the firepower backup? since they have put it without IP.
The 2 firepower are in HA.
