Aviso: la función para cargar archivos ha sido deshabilitada, lamentamos los inconvenientes.
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Connection between vlans
diegonchoo
Good morning dear community, I have a problem for which you may have an answer.
It turns out that I have a topology like this, my problem is: I want the existing vlans to get IP addresses through DHCP and that forces me to make sub interfaces, but when I do this configuration, the consequence is that different vlans have connection, I don't want them to connect to each other, but I want them to get DHCP from the router.
What is the solution to this problem?
TopologyTopology
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
balaji.bandi
if you do not like to connect to each other you need to apply IP ACL on the interfaces each to block and rest allow.
example :
ip access-list extended myblock-list
deny ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255  (example vlan 20 192.168.2.0 vlan 30 192.168.3.0)
permit IP any any
interface gig 1/1.10
ip access-group myblock-list in
BB
Ver la solución en mensaje original publicado
1 RESPUESTA 1
balaji.bandi
example :
permit IP any any
BB
