cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
Emulate Cisco Switch in Vmware
babalao
Is it possible to emulate/run a Cisco Switch in Vmware workstation for example ? I know I can run the router Catalyst 8000v.
I would like the same but with a switch. The purpose is to practice and test networks with switches,routers,FWs ,etc.
PS: I can not use GNS3 or similar
Thank you!
6 RESPUESTAS 6
balaji.bandi
Now sure what switch, but Cat 9K virtual is available for testing.
BB
where can I find this image to download? Can you tell me more because I did not find it in cisco to get it.
Is it an .ova file?  Would I have all the features of a catalyst 9k switch?
Thank you!
It may not be clear my last post-Cat9Kv is available with CML 2.8
https://developer.cisco.com/docs/modeling-labs/cat-9000v/#cat-9000v
BB
And does anyone know if it is possible to run a Switch cisco on VMware ?? just I would do a CSR 1000v for example.
Thank you.
Does anyone know if this is possible?
Thank you!
Any comment? The idea is to run/emulate switching features on vmware...
