cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
HSRP
Gordon Freeman1
Hola, espero puedan ayudarme con este ejercicio. He configurado HSRP en 2 switches capa 3 para amabs vlans, pero ambas tiene el estado de activo en ambos switches. Adjunto mi configuracion de interfaces y HSRP Menciono que ambos swtiches tienen un channel group con ip.
MLS1 =================================================================
vlan 10,20
interface Loopback0
ip address 100.1.1.1 255.255.255.255
interface Port-channel1
switchport trunk allowed vlan 10,20
switchport mode trunk
switchport nonegotiate
interface Port-channel3
no switchport
ip address 10.0.6.1 255.255.255.252
interface Ethernet0/0
no switchport
no ip address
channel-protocol pagp
channel-group 3 mode desirable
interface Ethernet0/1
no switchport
no ip address
interface Ethernet0/2
no switchport
no ip address
interface Ethernet0/3
channel-protocol lacp
channel-group 1 mode passive
interface Ethernet1/0
no switchport
ip address 10.0.1.2 255.255.255.252
ip ospf authentication key-chain LLAVE1
ip ospf network point-to-point
ip ospf dead-interval 20
ip ospf hello-interval 5
ip ospf cost 20
duplex full
interface Ethernet1/1
no switchport
ip address 10.0.5.2 255.255.255.252
ip ospf cost 5
interface Ethernet1/2
interface Ethernet1/3
interface Vlan10
ip address 172.16.10.2 255.255.255.0
ip helper-address 10.0.1.1
standby 10 ip 172.16.10.1
standby 10 timers msec 200 msec 800
standby 10 priority 150
standby 10 preempt
interface Vlan20
ip address 172.16.20.2 255.255.255.0
standby 20 ip 172.16.20.1
standby 20 timers msec 200 msec 800
standby 20 priority 80
router eigrp ENARSI
address-family ipv4 unicast autonomous-system 100
af-interface default
passive-interface
exit-af-interface
topology base
redistribute ospf 1 route-map ospf-to-eigrp
MLS1 con0 is now available
Press RETURN to get started.
MLS1>EN
MLS1#sh
MLS1#show runn
MLS1#show running-config
Building configuration...
Current configuration : 3729 bytes
! Last configuration change at 20:31:18 CET Sat Dec 9 2023
version 15.2
service compress-config
hostname MLS1
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
clock timezone CET 1 0
vtp mode transparent
ip cef
no ipv6 cef
key chain LLAVE1
key 1
key-string enarsi123
cryptographic-algorithm hmac-sha-256
spanning-tree mode mst
spanning-tree mst configuration
name ENARSI
revision 1
instance 2 vlan 10
instance 3 vlan 20
spanning-tree mst forward-time 16
spanning-tree mst max-age 10
spanning-tree mst 2 priority 28672
spanning-tree mst 3 priority 24576
vlan 10,20
interface Loopback0
no switchport
no switchport
no ip address
no switchport
no ip address
no switchport
no ip address
no switchport
ip ospf cost 20
duplex full
no switchport
ip ospf cost 5
interface Vlan10
standby 10 preempt
interface Vlan20
MLS2
vlan 10,20
interface Loopback0
ip address 100.2.2.2 255.255.255.255
interface Port-channel2
no switchport
ip address 10.0.6.2 255.255.255.252
no switchport
no ip address
channel-group 3 mode auto
no switchport
no ip address
no switchport
no ip address
no switchport
no ip address
no switchport
ip address 10.0.2.2 255.255.255.252
ip ospf cost 20
channel-group 2 mode active
interface Vlan10
ip address 172.16.10.3 255.255.255.0
ip helper-address 10.0.2.1
standby 10 priority 80
interface Vlan20
ip address 172.16.20.3 255.255.255.0
standby 20 priority 150
standby 20 preempt
"GRACIAS DE ANTEMANO"
3 RESPUESTAS 3
M02@rt37
Hello @Gordon Freeman1
En la interfaz Vlan10 en MLS1, la prioridad HSRP está configurada como 150. Asegúrate de que sea menor que la prioridad configurada en MLS2 para la misma VLAN (Vlan10). Cambia la prioridad a un valor menor, por ejemplo, 120:
interface Vlan10
standby 10 priority 120
En la interfaz Vlan10 en MLS2, la prioridad HSRP está configurada como 80. Asegúrate de que sea mayor que la prioridad configurada en MLS1 para la misma VLAN (Vlan10). Cambia la prioridad a un valor mayor, por ejemplo, 110:
interface Vlan10
standby 10 priority 110
En la interfaz Vlan20 en MLS2, la prioridad HSRP está configurada como 150. Asegúrate de que sea menor que la prioridad configurada en MLS1 para la misma VLAN (Vlan20). Cambia la prioridad a un valor menor, por ejemplo, 90:
interface Vlan20
standby 20 priority 90
Después de realizar estos cambios, espera unos momentos y verifica el estado de HSRP en ambos switches para ambas VLANs. Los switches deberían sincronizarse y uno de ellos debería ser el activo mientras que el otro es el en espera para cada VLAN.
Best regards
He probado la configuracion y siguen saliendo ambas vlans en ambos switch como activas, compartiré mi confirmación de MST en caso de que ese sea el problema. Debo destacar que el objetivo es que MLS1 tenga vlan 10 como activa y vlan 20 como standby, MLS2 vlan 10 como stanby y vlan 20 como activa.
MLS1==========================================
name ENARSI
revision 1
instance 2 vlan 10
instance 3 vlan 20
MLS2===================================
name ENARSI
revision 2
instance 2 vlan 10
instance 3 vlan 20
spanning-tree mst 2 priority 24576
spanning-tree mst 3 priority 28672
balaji.bandi
i want to point to couple of things.
1. One of the switch running MST - so make sure you have running spanning tree correctly, since this very important when layer 2 between switches.
2. Alaways use different priroty value - so Right device can act as HSRP active (in your case both use same value, so lower the priority the one you looking to be standby  - (default is 100).
3. Use always HSRP v2 for better outcome and many bugs fixed - by issue command on the interface both the side. (standby version 2)
BB
