cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Upgrade Cisco Prime 3.1 -> 3.7 -> 3.10
nstr1
I have a PI v3.1 i want to upgrade to 3.10 then,
I need to upgrade from 3.1 to 3.7 and finaly from 3.7 to 3.10.
I found this file which allows me to upgrade from 3.1 to 3.7.
But I can't find any file that allows me to upgrade from 3.7 to 3.10.
How can I update my PI from 3.7 to 3.10???
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hello @nstr1
There will not be this transition from 3.7 to 3.10.
On  the 3.10 upgrade guide, you can read this
Note
If your existing Prime Infrastructure is 3.7.x or 3.8.x, and your upgrade path contains 3.4.x or earlier versions, then you cannot in-line upgrade that server to Prime Infrastructure 3.9 due to security vulnerabilities in the underlying Red Hat 6 installation. You will need to take a backup of the Prime Infrastructure 3.7.x or 3.8.x server, deploy a fresh Prime Infrastructure 3.9 server, and restore that backup into the Prime Infrastructure 3.9 server.
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
Hello @nstr1
Note
Thank you @Flavio Miranda
Thank you,
I even just came across this piece of information.
Right on!
 Thanks for rating!
I have carried out the process to have cisco prime 3.10.
In other words, I upgraded from prime 3.1 to 3.7 and I already have a new virtual machine with version 3.10 and it already has the prime 3.7 backup.
Now I have another question, the license that Prime 3.1 had is automatically migrated to Prime 3.10?
