Cisco ASA and DUO MFA
Linus02
we have connected our Cisco ASA 5506 with cisco DUO MFA Cloud. successfully.
Our Anyconnect clients get a second password box, where we can enter push or phone to receive push notifications in the DUO App, or a Phone call/sms via Cell.
BUT, we only want PUSH for all of us, without entering “Push” or “Phone” in the second box.
Is this possible?
Greetings from Germany
Malte
DuoPablo
Hi @Linus02 ,
If you configured your ASA using the Duo for ASA LDAPS integration type, then the 2nd password field is required. You may choose to customize this field via Knowledge Base | Duo Security.
The RADIUS and SAML integration types for Cisco ASA do not require a 2nd password field. Pease see What are the differences between the various Cisco ASA configurations?
Hope this helps!
