DUO visio stencils and icons
sameer.dy09
Are there any known or standard Stencils or icons available for DUO.
Sam
Amy2
Level 5
Level 5
Hi Sam, thanks for your question! As far as I know, Duo does not have any stencils or icons for Visio. I am confirming with the wider team to be sure though.
The only thing I could find are these non-Visio templates for Duo Mobile and the Duo Prompt, but these are more for end-user communication and documentation. I assume you’re after something to help create network diagrams.
Thanks Amy
I am specifically looking for the icon used in DUO PPTs for Auth proxy and DUO cloud to put a design for the environment.
Let me know if there is any icons/samples available
Sameer
Ah cool, thank you for specifying what you need! We actually do have something like this. Will these work for your purposes?
Apologies that they’re huge haha I wanted to ensure the best resolution.
Thanks it works
Sam
