How to use Duo MFA as main aunthentication method
rsacramento
Hello.
Is it possible to use Duo MFA as main authentication method ? Where the user does not need to type logon password, only use the Duo mobile app.
All
6 Replies 6
Amy2
Level 5
Level 5
Hi @rsacramento, no it’s currently not possible to Duo for primary authentication. However, you might be interested in our Duo Passwordless solution which is now available in a public preview. At the end of that blog post are a number of videos which explain more. I hope that helps!
Thanks for your help.
I gonna take a look on this new solution.
BusterDoney
Actually it is possible to use Duo MFA as the primary authentication method. Some conditions apply:
  • You need to use ADFS 2019 as your Identity provider.
  • The application in question needs to be integrated with ADFS for SAML or OpenID.
  • You can require Duo as your primary auth but users are still required to enter their password as their secondary auth; however, there are many options available for Keep Me Signed In, Certificate-based auth in lieu of passwords, tokens, Windows Hello for Business, etc.
Take a look at Protect the Password feature for ADFS to learn more about using MFA as your primary auth method. This isn’t a feature of Duo but rather a feature of the IdP.
Hi all,
I have encountered an issue while using DUO as Primary Authentication Method for ADFS.
Meanwhile, I've found this post.
When I use DUO as Primary Authentication in ADFS (i.e. accessing SAML2 integrated Shibboleth SP App with SP-initialized). The below error happen when an invalid user (i.e. User not exist in AD) information is used.
See if anyone encounter this problem also?
Patrick
Of course AD FS looking up a non-existent user fails when the user doesn't exist in the directory?
Duo, not DUO.
Hi Kristina,
Many thanks for your reply. I found it the error is better if using OpenID Correct integrated application
They will not throw the error to the application side and the error message is more meaningful.
