06-30-2022 12:00 AM
I have installed an application in the IOx Sandbox. The application stores users data in a file and that file needs to be mounted outside the container so that the data in the file is not lost when the container restarts. Please let me know the file mounting process in IOx. How do I access file system of IOx sandbox located outside the container ? Thank you.
06-30-2022 12:02 AM
personally, i do not believe that is possible.
07-05-2022 12:16 AM
When you run an IOx application, a folder /data will be created where files can be stored. These files can be accessed OUTside and INside of the container. https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/guides/iox/lm/reference-guide/1-4/iox_local_manager_ref_guide/workflows.html#21539
Check if that fits to your needs.
