Bookmark
Subscribe
1919
Problem with Cisco ESA and alerts
Zach_Sec
one of our customers are getting this kind of alert messages to their email boxes:
The Warning message is:
Unable to connect to Cisco Web Security Service.
URL Filtering will not work correctly.
Please verify all network, proxy and firewall settings.
Connection to "v2.sds.cisco.com" failed.
The last error seen on this connection: "Server busy or service unavailable"
Version: 10.0.1-087
In the past few months, there weren't any alerts like this, but recently we'v got many. I looked up everything on google that could lead to something helpful to resolve this problem, but nothing helped.
We tried to change the DNS servers, and it didn't help. We saw this: https://www.cisco.com/c/en/us/support/docs/field-notices/641/fn64111.html
but it didn't help. One thing that i saw interesting is that when i made a packet capture on the ESA, i saw that the ESA is making a TCP RST in the same time when the alert is being made.
For some reason, v2.sds.cisco.com resolves sometimes to 172.110.204.44 or 198.148.79.60, and the problem seems to only occur when the ESA is making a URL update using the 198.148.79.60 address.
Any suggestion would be helpful.
Thank you in advance,
Zach
7 Replies 7
Libin Varghese
Cisco is working diligently to address this issue.
In order to mitigate and reduce the number of alerts being received by affected customers, we have recently added capacity to the update service to better address the overall load while we continue to isolate the root cause of the alerts.
Please note that the alert itself is an informational warning only and does not impact the performance or operation of the appliance.
Libin Varghese
Thank you very much for the information!
Best regards,
Zach
Any news regarding this? Or is it going to take some time to fix the issue?
Best regards,
Zach
As per the last update additional servers were added to handle the load being seen which should have reduced the number of alerts.
Could you confirm since when you began seeing the alerts and what is the frequency of these alerts per day/per hour?
- Libin V
It looks like it didn't get better. The alerts are coming in a interval of 2-4 hours.
Best regards,
Zach
Do all alerts end in "Server busy or service unavailable" or are there alerts with other error codes as well?
I'll check if there are any further updates.
- Libin V
They all end in "Server busy or service unavailable".
Best regards,
Zach
