RV325 Router -login
sydney-vwalika
Hello!
I have a challenge trying to login on a new cisco RV325, failing to open a login page on a browser, but able to ping 192.168.1.1. Kindly assist me on this am new to cisco products
17 Replies 17
Yes, I can view them now and all seems normal.
I found something interesting in the Admin guide:
NOTE Network access including router's management utility will be blocked from LAN when all LAN ports are configured with Force Unauthorized.
Reset to factory default will be required if remote access is not enabled.
Can you try reseting the router to factory defaults by pressing the reset button for 30 seconds?
Regards, LG
*** Please Rate All Helpful Responses ***
Okay let me try that
Hello @sydney-vwalika ,
any updates on accessing the router after the factory defaults reset?
Regards, LG
