cant access asdm after changing inside ip?
baselzind
Level 6
Level 6
i have asa 5520 , i dont understand why when i changed my inside ip address i can no longer access the asdm? even though i have set the access tange for asdm https 0.0.0.0 0.0.0.0 inside?
check on the Switch it was connected, and clear arp table in the switch and check again.
BB
5 Replies 5
Marvin Rhoads
Did you change the subnet or just the host address within the subnet?
If it's the former then routing may also need to be updated.
I just changed the ip not the subnet and now i cant access the asdm
what was the IP before it was working, what is the IP you have changed ?
what is the error you getting while you access the NEW IP,
Do you have reachability from your PC to new Manangement IP of ASDM ?
BB
it was 172.16.50.40 and i changed it to 172.16.50.100
BB
