Order of operation ASA
ring zer0
I am looking for a document on cisco asa order of operation in a post 8.3 OS. I found following link but it looks like to be of 8.2 only ,
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113396-asa-packet-flow-00.html
Please advise if there is any document for this.
Marvin Rhoads
Cisco Live presentations are a good source for this sort of information.
Specifically, have a look at BRKSEC-3020 "Troubleshooting ASA Firewalls" from the 2015 Melbourne running. There is a whole lot of detail including the following slide (open in new tab to zoom):
Vibhor Amrodia
I am not sure if there is any document by i will take a look at it.
For now , you can reference the same document with the only change on the ACL phase.
In the ASA 8.3+ , the NAT or match xlate phase will come before the ACL check.
Thanks and Regards,
Vibhor Amrodia
Exactly right that. Everyone needs to be focused on version detail, especially for firewalls.
Marvin Rhoads
