stateful firewall problems (IOS)
patrickavery
What is the correct way to implement stateful firewall inspection using CBAC? I recently used the following configuration to permit outbound web and other traffic to work through my IOS firewall.
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
int fa0/1
description OUTSIDE
ip inspect SDM_LOW out
ip access-group 103 in
When I used this, browsing worked sometimes. For instance if I pulled up http://www.yahoo.com it would give me a page failure 3 times and then work. When I went to http://www.cdw.com I would get broken images but the page would load. When I would go to http://www.google.com everything would work fine.
To fix this, I added a permit established acl entry to acl 103 and removed the outbound inspection. If I only added the established acl, the problem persisted.
The inbound rules in acl 103 work fine.
Obviously I am missing something with the whole CBAC stateful inspection. Any ideas?
8 Replies 8
Fernando_Meza
Level 7
Level 7
Hi .. I suggest you to apply the inspection rule to the Interface which protects your internal devices.
i.e f0/0 Internal interface linked to your LAN
f0/1 external interface linked to your ISP
1.- configure access-list allowing also the required traffic that you want to inspect and apply it to the inside interface on the inbound direction.
Int fa0/0
description INSIDE
ip access-group 100 in
2.- configure access-list to deny any traffic that you don't want to be initiated from the Internet towards your internal network and apply it on the Inbound direction to the outside interface.
int fa0/1
description OUTSIDE
3.- create inspect rule and apply it to the INSIDE interface on the inbound direction.
ip inspect name SDM_LOW tcp timeout 3600
ip inspect name SDM_LOW udp timeout 15
Int fa0/0
ip inspect SDM_LOW in
NOTE; you need to make sure that your ACLs which apply to the traffic LEAVING your internal network are not blocking the traffic that is to be inspected ..otherwise CBAC inspection will not work as expected.
I hope it helps .. please rate it if it does !!!
I tried that as well. Realize the only difference between suggestions and original config are the placement of the inspect statements. I'm pretty sure they are equivelant. Anyhow, no dice.
Here is exactly what I have.
ip inspect name SDM_LOW udp timeout 300
int fa0/1
description OUTSIDE
int vlan 1
description INSIDE
ip access-list extended 103
10 deny SPOOFED STUFF
20 deny BAD PROTOCOLS
...(permit inbound services like http & ssh to specific hosts)
1200 deny ip any any log
ip access-list extended 100
...(more spoofed stuff)
50 permit ip any any
Now if I remove the ip inspect statements and add "20 permit tcp any any established" to the ACL 103 outbound works fine.
Otherwise Internet browsing works sometimes. It almost seems like CBAC is doing some sort of content filtering but that doesn't make sense. For instance it pulls up http://www.cdw.com but many images are broken. Works fine with some pages and awfully with others.
I have tried your solution and unfortunately I have not seen that it helps the situation any. I am personally leaning to a Cisco IOS issue. What are the commonalities between each of our issues? The following are my specs:
- Cisco 2821 Router
- c2800nm-advsecurityk9-mz.124-9.T1.bin
ryan.kucharo
I am having the EXACT same issue. I believe that it may be an IOS issue. I am running c2800nm-advsecurityk9-mz.124-9.T1.bin. It seems to be directly related to the Application Firewall. I would paste my config, but its nearly identical to your two. If anyone has any ideas on how to fix this permanatly without turning off the APPFW, I would greatly appreciate input.
When I first began having this issue I was running c2800nm-adventerprisek9-mz.124-10. I have since then switched to c2800nm-advsecurityk9-mz.124-3g. Changing to the only GD code for 12.4 Security didn't help.
What's the output of a show ip inspect all?
The only thing I can think of if it's 'intermittent' is that you are hitting some of the connection limitations (max incomplete or one minute high/low). this would explain why you would get part of the cdw page - but some images (which are coming from other sites) might be incomplete, as those would be new http connections to those sites.
--Jason
Currently my show ip inspect all is as followed.
RTR1#show ip inspect all
Session audit trail is disabled
Session alert is enabled
one-minute (sampling period) thresholds are [400:500] connections
max-incomplete sessions thresholds are [400:500]
max-incomplete tcp connections per host is 50. Block-time 0 minute.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 30 sec
dns-timeout is 5 sec
Inspection Rule Configuration
Inspection name SDM_LOW
http java-list 99 url-filter is on alert is on audit-trail is off timeout 36
00
(Output Omitted)
Interface Configuration
Interface MFR0.646
Inbound inspection rule is not set
Outgoing inspection rule is SDM_LOW
00
(Output Omitted)
Inbound access list is 103
Outgoing access list is not set
Established Sessions
(Output Omitted)
All right.
Well, I've had some problems in various locations with this, it *may* or may not be the same issue.
A couple of recommendations:
enable the audit trail so you can see what inspects 'issue' is.
ip inspect audit-trail
also, I would increase all the session thresholds (note - if you're worried about hosts doing DOS attacks, then play with these numbers):
ip inspect max-incomplete high 5000
ip inspect max-incomplete low 4800
ip inspect one-minute high 5000
ip inspect one-minute low 4800
ip inspect udp idle-time 60
ip inspect tcp idle-time 43200
ip inspect tcp synwait-time 60
ip inspect tcp max-incomplete host 200 block-time 0
I would then try the connections again and see how it goes - turn the log buffer up to debug and see what inspect is complaining about.
Hope this helps!
--Jason
Please rate this message if it solves some or all of your question/issue.
