12-14-2020 01:19 PM
Incorrect device configuration when using OpenConfig OSPF payload for NETCONF
Demonstration : https://youtu.be/7npu5QNF5No
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.3, RELEASE SOFTWARE (fc2)
from ncclient import manager import xmltodict import xml.dom.minidom xml_string = ''' <config> <network-instances xmlns="http://openconfig.net/yang/network-instance"> <network-instance> <name>default</name> <protocols> <protocol> <identifier xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:OSPF</identifier> <name>1</name> <config> <identifier xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:OSPF</identifier> <name>1</name> </config> </protocol> </protocols> </network-instance> </network-instances> </config> ''' m = manager.connect( host='ios-xe-mgmt.cisco.com', port=10000, username='developer', password='C1sco12345', hostkey_verify=False ) netconf_reply = m.edit_config(xml_string, target = 'running')
OSPF process 1 configured.
BGP for ASN 1 configured.
12-15-2020 10:13 AM - edited 12-15-2020 10:16 AM
Hello Renato,
I found a bug from this exact software version release related to NETCONF.
URL:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp13260
Symptom:
netconf-yang command can not use after 16.9.3 upgrade
Workaround:
Change redundancy mode to none and reboot
I hope this helps!
Best Regards,
Alex Stevenson
