9200L capabilities ISE 2.2
yajick
Hi Team,
A customer of mine is currently running ISE 2.2 and they have purchased some new Cat9200L. They have plans to upgrade to the new code base but there is now a compelling reason for them to insert the 9200L in their network before they hit the change window when they will be able to upgrade.
They want to understand what type of support (if any) the 9200L will have on the 2.2 code base, and what capabilities will/won't work.
Anyone come across that before or can point me in the right direction?
Cheers,
Yaj
yadaby@cisco.com
ldanny
I dont think this has been vetted , although it does support 9300 , 9400, 9500.
I cant imagine it would not support the 9200 but in a cases like this I would recommend testing in a lab.
If you do happen to test this yourself please share results.
Thanks Jason,
I believe this gives me some indication on how to direct my customer.
Cheers,
