How to integrate with Palo Alto?
haimeng
How can we integrate Palo Alto firewall to share session information regarding AD and ISE authentication sessions with Palo Alto firewall? Can we do this with PxGrid or web socket?
3 Accepted Solutions
Nidhi
As Surendra mentioned, PAN does not have integration over PxGrid.
You can find few documents on VSA and TACACS configuration here - https://community.cisco.com/t5/security-documents/ise-security-ecosystem-integration-guides/ta-p/3621164#toc-hId--1636445697
jeppich
PAN has an open integration with pxGrid that is not supported.
John
jeppich@cisco.com
Thanks John,
Can you elaborate on this one? Where can I find more information?
7 Replies 7
Surendra
Palo Alto firewalls do not talk pxGrid. You can probably send syslogs to the firewall configuring them as Remote Logging Targets on the ISE and configure Palo alto to parse them.
See this http://k12itdir.blogspot.com/2016/02/paloalto-user-id-from-cisco-ise-nodes.html . Disclaimer: Not a Cisco document and may or may not help you.
Nidhi
jeppich
John
jeppich@cisco.com
Thanks John,
Hi Hailu
Please have your customer contact Palo Alto for any further information.
craiglebutt
Level 4
Level 4
Do you still have an issue with this?
You need to contact Palo Alto directly.
