Cisco IR829 does not ping and cellular does not get ip address
zentinelcorp
hello i am trying to configure my cisco 829 with this simple code snipped but the device refuse to ping 8.8.8.8 or 0.0.0.0 etc and the cellular 0/0 or 1/0  refuse to get ip address, i use a generic sim card and i dont know if the problem is related to that but the sim cards seems to be active and working
ipv6 unicast-routing
controller cellular 0/1/0
profile id 1 apn m2m.tele2.com
int cellular 0/1/0
ip address negotiated
dialer in-band
dialer idle-timeout 0
dialer-group 1
ipv6 enable
no shut
access-list 1 permit any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
dialer watch-list 1 ip 5.6.7.8 255.255.255.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
ip route 0.0.0.0 0.0.0.0 cellular 0/1/0
ipv6 route ::/0 Cellular0/1/0
pnp profile pnp_cco_profile
transport https host devicehelper.cisco.com port 443
do-exec write memory
and this is my sh cellular 0/0 profile
To:​
You
Tue 30/04/2024 16:15
R800#sh cellular 0/0 profile
Profile 1 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = none
Authentication = None
Profile 3 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = verizon
  * - Default profile
** - LTE attach profile
i have checked already and it did not work, this is my sh running-config and the model of the device is IR 829 2LTEEA 8K9, i am using a IOT sim card from Eliotclub
Current configuration : 3777 bytes
! Last configuration change at 19:32:26 UTC Tue Apr 30 2024
version 15.7
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11
no ignition enable
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-BK9 sn FTX2223Z023
vtp mode transparent
redundancy
controller Cellular 0
lte sim data-profile 3 attach-profile 3
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
controller Cellular 1
no lte gps enable
vlan 11
name 10.202.241.0/24_DATA
interface GigabitEthernet0
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer enable-timeout 6
dialer string lte
dialer-group 1
no peer default ip address
ipv6 address dhcp
async mode interactive
routing dynamic
interface Cellular1/0
encapsulation slip
shutdown
dialer in-band
dialer string lte
dialer-group 1
ipv6 address autoconfig
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
no ip address
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface Cellular0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular1/0
ip access-list extended NAT
permit ip 10.0.0.0 0.0.0.255 any
ipv6 ioam timestamp
control-plane
vstack
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
line 9
script dialer lte
no exec
line 15
no exec
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
