IE4000 Zero Touch Provisioning
TBath1413
I need to deploy 1000's of IE4000 switches throughout the world but I would like to use ZTP similarly to the way we use for datacenter switch deployments.  I don't have the IE4000's in hand but I can seem to find anything on ZTP with the IE4000.  Am I missing something?  Is this possible with the IE switch series?
Albert Mitchell
the IE4000 is running IOS.  as such any Day1 application will work.  examples of day 1 applications to help you auto install IE4000's
1. Plug N Play.
2. dhcp based Auto Install : https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie4010/software/release/15-2_4_EC/configuration/guide/scg-ie4010_5000/swipaddr.html
3. Express Setup - this is a manual process requires IE4000 be co-located with operator
Thanks so much for the Auto-Install info should take care of this for me.  I guess they just aren't calling it ZTP on the IE switch series.
