01-23-2023 08:09 AM
I’m attempting to put our IOT Amazon Thermostats on a VLAN with a restricted ACL. It allows access to Internet, DNS, and DHCP. Deny access to all other Vlans and devices. The ACL I have works on test PC’s place on the Vlan. But when connecting the thermostats to WiFi on the Vlan thermostat receives DHCP lease, gets out to the internet, but when finalizing communication with the Amazon App it cannot connect.
Does anyone know what ports or communication profiles / ports need to be added to the ACL for this to work?
01-23-2023 08:11 AM
what device mode and code running, how is your ACL look like ?
01-23-2023 08:21 AM
Vlan IP is 192.168.175.0 /24
The Thermostat is Amazon Smart Thermostat. I do not know the Code used. It connects to Amazon Smart app on mobile device.
ACL: IOT_
ip access-list extended IOT_OUTBOUND
10 permit icmp any any
20 permit tcp 192.168.175.0 0.0.0.255 any eq www
30 permit tcp 192.168.175.0 0.0.0.255 any eq 443
40 permit udp 192.168.175.0 0.0.0.255 host 192.168.1.238 range bootps bootpc
50 permit tcp 192.168.175.0 0.0.0.255 host 8.8.8.8 eq domain
60 permit tcp 192.168.175.0 0.0.0.255 host 192.168.1.238 eq domain
70 permit udp 192.168.175.0 0.0.0.255 host 192.168.10.52 eq domain
80 deny ip any any log
ip access-list extended IOT_INBOUND
20 permit tcp any eq www 192.168.175.0 0.0.0.255
30 permit tcp any eq 443 192.168.175.0 0.0.0.255
40 permit udp host 192.168.1.238 range bootps bootpc 192.168.175.0 0.0.0.255
50 permit tcp host 8.8.8.8 eq domain 192.168.175.0 0.0.0.255
60 permit tcp host 192.168.1.238 eq domain 192.168.175.0 0.0.0.255
70 permit udp host 192.168.10.52 eq domain 192.168.175.0 0.0.0.255
71 deny tcp any range telnet 24 192.168.175.0 0.0.0.255 range telnet 24
01-23-2023 08:56 AM
that is end device, what is the model of the device you using this ACL, what IOS code running on it ?
01-23-2023 02:38 PM
Cisco C9300-48P Catalyst 9300
ver17.3.4
01-24-2023 12:44 PM
Can you post full config - i would like to see NAT, also you mentioned PC works and device you looking not working
can you give example when you connect PC, what IP it got ? when the device not working what IP it got ?
you do not need inbound ACL - is this device directly connected to internet ? how is your network diagram looks like ?
