IR1101 P-LPWA-900 Module Deployment
chrispybacon
I'm trying to deploy a P-LPWA-900 LoRaWAN gateway module on an IR1011.  To connect it to AWS, two certs need to be installed.
On an IXM, there is a cert install command to be able to do this.  Is there an equivalent command to be able to do this with the P-PLWA-900 module on an IR1101?
gstefanidis
Have you found the solution?
