11-17-2011 05:45 PM
Calculating values of fields and preventing submission
Dear All,
We have some fields on one of our forms that must add up to 100% and ideally prevent submission if they do not. At the moment, we rely on the customer filling out the form to get the split correct, but it would be a great help if we could calculate these values and provide feedback.
Please find a screenshot of the particular AFC below. And thoughts or suggestions would be greatly appreciated.
11-17-2011 05:45 PM
In 2008, your choices are JavaScript or a data retrieval rule.
SQL-entry data retrieval rule would probably be simpler: Just select the sum of the fields (from Oracle, select from dual) into a hidden (or not) field. (In SQLServer, it's just select, without the dual):
select (#Dict.AllocatedPct1# + #Dict.AllocatedPct2# + #Dict.AllocatedPct3#...) AS Alias from dual
mapping the alias column to the HiddenField (or not) on the AFC
Since data retrieval rules (unlike fetch [RIP]) are per
11-17-2011 05:45 PM
I have a similar requirement and accomplished it using javascript in 2008.3 version. I did not think to use data retrieval rule functionality. In addition, I am not following your syntax from dual statement for SQLServer, but let me try it. Thanks.
11-17-2011 05:45 PM
DDR or JS.
On Submit add the values and if = 100 then nothing else error message and return false
11-17-2011 05:45 PM
That's an excellent start! Thank you for your feedback. I will investigate and report back!
