Bookmark
Subscribe
1177
Cisco IAC 3.1 - VLans added but not available ?
otavio.augusto
Hi all
When trying to create my first VDC, I see no items at the VLans dropdown list. I have created all VLans I need (System Setup portlet -> Networks tab -> Add a N etwork). Is there any configuration I'm missing? Anything else I should do in order to have such VLans available ?
Thank you
/O
Otavio Augusto
Lee Calcote
Level 3
Level 3
Do these networks have a vCenter portgroup and UCS VLAN associated? Do you see these networks listed in the Modify Network Properties service?
Hi,Lee
I've removed the previous installation so now I'm not able to check what you are suggesting. But as far as I remember, I had the networks listed in the "Modify Network Properties".
By the way: I'm associating portgroups to the networks I'm creating, but not adding UCS Vlans (they have been found by the portal but they are not a requirement for adding networks, right?)
Thanks for your reply.
