Conditional Rule - how do you setValue for Person type fields
Patti Richards
In the old ISF world, I used to code  the following to reset a person (select) type field:
serviceForm.INT_SHAREPOINT_NEWSITE_REQUEST.SecondaryAdmin_disp.setValue(['']);
You  had to specify <dictionary>.<fieldname>_disp.setValue
the  _disp was critical.
I am trying to code the similar function  using Conditional rules. I tried the set Value action to null/blank, but  it didn't work on the person field.
Is there anyway to do this  with Conditional Rules? I hope i don't have to go back to ISF for this  one.
Please help!!
13 Replies 13
Jegannath R
Hi Richards,
I tried the same thing with conditional rules and accomplished it.  I didnt do much apart from setting the value to null. See the snapshot below.
I set the literal value empty and triggered the rule on some field click.
Jegan
Patti Richards
Thanks the response. I think we are on a different version of Request Center (2008.3). We have the radio button for literal and a radio button for null/blank, but neither seem to work to clear out the person field. It is on an onClick event. Probably a "defect". I'll file a case. What version of RC are you on?
Our literal option wouldn't let us submit it as empty had to put a "space" char in it, but that didn't work either.
Patti Richards
here's the conditional rule setting from RC2008.3
Hi Patti,
We're on 2008.3 and I'm having the same issue as you - the 'set value' option works for all field types except the person field.  I'm going to file a case for this too.
Jegannath R
We are in 2008.1 and do not have a specific radio for null/blank. And yes I just tried triggering a rule on click event for testing.
Patti Richards
Good news! We installed service pack 6 in our dev environment, and it has fixed the problem. If you look at the release notes with service pack 6- Bug ID # 26360  Customer Issue ID #11682. We just tested it out today.
Hi Ed,
Is it possible to be set to Other values; not just Null?
Ant
There was a reported bug regarding this behavior which has been fixed in  Service Pack 6 for newScale 2008.3. Here is the information on this  item from the release notes for that Service Pack:
Bug ID
Customer Issue ID
Resolution Summary
Hi Ant,
It sure is! The Set Value conditional rule action will allow you to set the value to a literal, to a value in another field, or to Null/Empty/Blank.
Hi Ed,
When one is setting a Person type field to a value using Conditional rules; how does one map it to the Person object in the RequestCenter database?
Ant
Thanks Leslie; that'd explain it - we're on 2008.1, and using legacy Dictionaries that aren't Person-based.
Will keep that mind moving forward.
Thanks again,
Ant
You need to copy a PersonID to the person_search field in a person based dictionary. That will trigger the pre-fill of other fields in the dictionary, based on that personID. This works in versions 2008.2 and above.
gary dzurny
does this approach stil work with the latest version of newScale?  I am copying a supervisorID to this field via a conditional rule in hopes it would populate the rest of the person based dictionary information and it does not seem to work.
