CUCM Provisioning automation with CPO 3.0
Ayaz Ahmed
I am trying to automate VoIP phone provisioning using CPO 3.0 and Cisco Unified Call Manager which has a secured SOAP interface exposed on https port 443. When trying to load the SOAP wsdl into the Web Service Execute adapter, it is throwing an error.
Exception has been thrown by the target of an invocation.
As an alternative I tried to inject SOAP message using Web http Request adapter I am getting the following error
The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. The remote certificate is invalid according to the validation procedure.
I don’t see any option to attach self-signed certificate using the Web http Request adapter.  Has anyone tried using secured SOAP interface of CUCM with CPO 3.0 or higher?
Ayaz Ahmed
Xerox Cloud Service
Shaun Roberts
Couple of questions...
1) Have you been able to do this in something like SOAP UI? If so, did you look at the raw data/message and make sure headers match/etc
2) Do you have to use SSL?
3) Which particular web call are you attempting to make?
4) What is the HTTPS endpoint WSDL you are trying to hit?
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
