Expand All in 6.0.3 client?
Michelle Morris
                   Hi Everyone.  I'm using IE9 and Firefox 14 with Tidal 6.0.3.140 and I am not able to get the Group Display-->Expand All to work in Job Activity or Job Definitions.  If I highlight a job parent and choose Expand All, it only expands that parent.  In 5.3.1 I was able to right click on the Jobs "folder" in the navigation bar on the left and choose Group Display --> Expand All and all of the parents would expand.
Is anyone else having the same symptom?
Thanks in Advance,
Michelle
Marc Clasby
right and left arrow keys to expand and contract all
it looks like a few keyboard shortcuts were dropped in the client manager connection
you used to be able to:
CTL+SHIFT and use the right and left arrow keys to expand and contract all
CTL+ right and left arrow keys to expand and contract the highlighted group(s)
As Michelle points out
Now you have to highlight the section/selection.. right click Group Display
in this case you need to highlight the entire shcedule def or activity and then group display
otherwise even if you select the expand all then it still will only to the selection you are on... not the whole list
we are still just demo'ing getting used to it ... I wonder what it will be like with a few thousand jobs in it...
That defect of not expanding all when selecting expand all can probably be quickly fixed by Tidal
Marc
