06-15-2015 04:39 AM
Hi Team,
Recently i have installed CPO 3.0.0 in one of my local servers. And also applied the patches 3.0.0.8, 3.0.0.9, 3.0.2. 3.0.2.10, 3.0.2.11, 3.0.2.12.
All are working fine without any issues. When i try to apply the patch "IAC_40_Patch4" it is saying that you can downgrade XML schema definition from 3.0.2 to 3.0.0.
Is there any possible way to downgrade 3.0.2 to 3.0.0 and apply the IAC patch. After appling the IAC patch i will re-apply the 3.0.2 patches.
Please provide some assistance to resolve this.
If the downgrade is not possible, please provide the re-installation process of CPO on the same server.
Thanks and Regards,
Vignesh.
Solved! Go to Solution.
06-15-2015 06:24 AM
What does IAC_40_Patch4 include? If it's just TAPs, you can try to import the TAP files manually.
06-15-2015 06:24 AM
06-15-2015 11:34 PM
thanks Tuan tran.
