How to Recall same activity (Sub process) if time out error occurs ??
msivarami3
Hi ,
  how to recall activity/subprocess if error occurs for activiy ???
My use case is : I need to make vCO call from cpo (either using Webtarget or using Windows Powershell Script Activity) . if time out error occurs i need to make same call again . Can any one please help on this .
SivaRam.
Shaun Roberts
There is no inherently built in "recall" however this is not hard to do through content authoring.
If you believe this activity to fail a lot then I would do this...
*Setup a local boolean variable, default to false
*Set a while-loop to run while that local boolean is false
*When the activity runs if it's state is Succeeded or Not failed then set the boolean to true
That should accomplish what you want, however following a best practice I would be a max retry on there to limit the number of times it would attempt before you need to alert yourself that there could be an actual issue.
-shaun
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun Roberts
-shaun
--Shaun Roberts
shaurobe@cisco.com
