Namespace for Authorisations
David Abbishaw
Is there a namespace that holds who (preferably the email address) approved the requisition?
Im hoping that we can do something like - #Service.Requisition.Approver.Email#
thanks
David
5 Replies 5
Emir E
if you send the email before the next tasks starts, I believe you can use Performer.*
Correct, it's only available before the next task runs.  After the following task is started you can't access the previous performers.
We had to use a complex SQL query to get that information after all tasks have run.  This was done in a task that used the SQL Adapater and placed the information that was found back in the request so it could be emailed in the following task.
Any chance you can share that complex SQL query?
I've used the following to pull in contact information for approvals / tasks after the fact. You need to replace [RequisitionID] and [TaskName] with the appropriate values for your request. If you only want e-mail address, you can pull out the DirPerson references and the join.
SELECT DirPerson.FirstName, DirPerson.LastName, DirContactInfo.Value AS Email FROM DirContactInfo
JOIN DirPerson ON DirPerson.PersonID = DirContactInfo.PersonID
WHERE DirContactInfo.PersonID =
SELECT PerformerID FROM RequestCenter.dbo.TxActivity WHERE TicketID =
SELECT RequisitionEntryID FROM RequestCenter.dbo.TxRequisitionEntry
WHERE RequisitionID = [RequisitionID]
AND TitleExpression = [TaskName]
AND ContactTypeID = 1
This is the query that we used:
select distinct a.RequisitionID as reqId, c.Subject as TaskName,c.CompletedOn,b.RequisitionEntryID as arrEntryId, d.Name as ServiceName, u.Loginname as 'ApproverId', t.FirstName + ' ' + t.LastName as 'ApproverName', r.Description as 'StateDescription', c.ActivityID, f.ChannelID from [RequestCenterDev2].[dbo].[TxRequisition] a join [RequestCenterDev2].[dbo].[TxRequisitionEntry] b on a.RequisitionID=b.RequisitionID join [RequestCenterDev2].[dbo].[TxActivity] c on c.ticketID= b.RequisitionEntryID join [RequestCenterDev2].[dbo].[DefService] d on d.ServiceId=b.ServiceId join [RequestCenterDev2].[dbo].[DirPersonExt] e on a.OwnerID=e.personID right join [RequestCenterDev2].[dbo].[XtrChannelInfo] f on a.RequisitionID = f.RequisitionID join [RequestCenterDev2].[dbo].[XtrChannelInfo] g on f.ChannelID = g.ChannelID join [RequestCenterDev2].[dbo].[TxActivity] h on g.ActivityID = h.ActivityID join [RequestCenterDev2].[dbo].[DefFSMState] r on c.StateID = r.StateID join [RequestCenterDev2].[dbo].[TxActivityAssignment] s on s.ActivityID = c.ActivityID join [RequestCenterDev2].[dbo].[DirPerson] t on t.PersonID = s.PerformerID join [RequestCenterDev2].[dbo].[DirNetworkInfo] u on u.PersonID = t.PersonID WHERE c.Subject IN ('Approver 1', 'Approver 2', 'Get Approvers') AND f.AgentID = 7 AND h.StateID != 3 ORDER BY reqId, ActivityID
