10-09-2014 10:58 AM - edited 03-01-2019 09:11 AM
i have this oracle db job that is using PL/SQL as job type and calls a procedure with parameters. this is failing and giving me output of
Task (100 - Create BulkLoad WIPPER File - Oracle) failed launch (java.sql.SQLException: ORA-06550: line 3, column 49:
PLS-00201: identifier 'TST1_' must be declared
ORA-06550: line 3, column 3:
PL/SQL: Statement ignored
Completed at 10/9/2014 6:00 AM
<SFS BulkLoad File PreFix.359> is a variable and has a value of 'TST1_'.
<SFS BulkLoad File Suffiix.360> is a variable and has a value of 'a'.
when i don't use a parameter and pass a value instead the job is working fine. please advise. thank you. - warren.
10-10-2014 08:09 AM
Hi Warren,
Try adding a declare section, ie,
DECLARE
myPrefix VARCHAR2 (5);
mySuffix VARCHAR2 (1);
BEGIN
myPrefix := pPrefix;
mySuffix := pSuffix;
and then pass myPrefix and mySuffix variables as parameters to WRITE_TO_FILE.
BR,
Derrick Au
10-15-2014 08:54 AM
thank you derrick. i tried your example and it did not work.
Task (500 - Create BulkLoad WIPPER File - Oracle) failed launch (java.sql.SQLException: ORA-06550: line 5, column 15:
ORA-06550: line 5, column 3:
ORA-06550: line 6, column 15:
PLS-00201: identifier 'A' must be declared
ORA-06550: line 6, column 3:
Completed at 10/15/2014 11:22 AM
10-16-2014 09:09 AM
Hi Warren,
Interesting, these are parameters and not identifiers.
In Parameters tab, let's try replacing variable <SFS BulkLoad File PreFix.359> with the actual value 'TST1_' and <SFS BulkLoad File Suffiix.360> with the actual value 'a'
10-24-2014 08:34 AM
i tried and it did not work. so i tried wrapping a single quote to the actual value from the variable definition and that works.
10-10-2014 08:09 AM
Hi Warren,
DECLARE
BEGIN
BR,
Derrick Au
