11-17-2015 07:20 AM
Since PSC 11, there is an annoying popup message each time an email template is updated : "Security threat detected. Remove the insecure code from the content...".
Note that PSC is the author of the insecure code by the automatic insertion of style attributes within HTML content...
Solved! Go to Solution.
12-03-2015 06:54 AM
There was a bug opened for this and it is going to be fixed in a later patch.
The HTML sanitizer alerts on invalid html, generating the message. It is supposed to only alert once per discovery. The main culprets I've found were setting attribute values to center instead of middle, and vice versa.
12-03-2015 06:54 AM
12-03-2015 07:00 AM
Thanks!
