Tidal Mass Updates
bruced63
I have a situation where there are 300+ Tidal jobs defined to run on a particular agent/adapter.  I need to move 200 of them to a different agent/adapter.  Is there an easy way to do this without having to open each job up one at a time?
Thanks in advance.
You can also make use of the SACMD utility which allows for batch processing (mass updates).
Step 1.
The command can be as simple as: modrule -i job_ID -h agent_name
Step 2.
Insert the command above into a text file, and insert additional command lines as needed for each job ID
Step 3.
Now to run the batch file, type: sacmd file filepath_of_text file
Step 4.
Kick back, relax, and enjoy the popcorn!!!
Best,
Derrick Au
5 Replies 5
Robert Gardner
Hey Bruce
There is no native way using the client to change that many jobs to a different agent unless those jobs were inheriting the agent from a parent group.
Bob
Step 1.
Step 2.
Step 3.
Step 4.
Best,
Derrick Au
Thank you so much, Derrick.  That worked perfectly.
Sincerely,
Bruce
tony.rice
If you have the 6.3 transport utility, you could export all the definitions, update the agent and re-import the updated XML, no?
That sounds doable.  I'm going to look into that further.
Bruce
