Setting up sensor in inline interface pair mode
Colin Higgins
Level 2
Level 2
I have never set up a sensor in inline interface pair mode, and I had a couple of questions about it
It is my understanding that traffic from one vlan would be forwarded to another through the sensor (and then you would set up your ispection policies).
But how then would you set up the SPAN or capture ACLs on the switching side? A monitor session will put a port in a disabled mode (although I think you can use the monitor session x destination <interface> ingress to allow traffic from it).
Or would you use the
switchport capure
command with FSPAN on both interfaces?
Any advice would be great
sawgupta
For inline-pair, configuration should be something like this
Assuming switchport to be 1/1 and 1/2. IPS port Gig0/0 and Gig 0/1
1/1 and Gig0/0 should be in one vlan, lets say 800.
1/2 and Gig0/1 should be other vlan, lets say 810.
switchport config:
1/1
switchport
switchport access vlan 800
switchport mode acess
1/2
switchport
switchport access vlan 810
switchport mode access
All traffic from vlan 800 will be sent to port under vlan 810 and vice-versa after inspection.
Sawan Gupta
Thanks & Regards, Sawan Gupta
sawgupta
switchport config:
1/1
switchport
1/2
switchport
Sawan Gupta
