1/0/1 g711ulaw n S_PROCEEDING DID_ONHOOK
Jason Hendrix
Hello all,
Issue is ports are not clearing after DID call drops. Shows as "proceeding" and is onhook. Clears out after i do a reboot but I do not want to do a reboot everyday. I have shut/no shut the voice-port and stil shows same. Any suggestions?
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
Voice VM-8FXS/DID  Port adapter
HPEiVG01#show voice call summary | include DID
1/0/0         -          -  -                                         DID_ONHOOK
1/0/2         -          -  -                                         DID_ONHOOK
1/0/4         g711ulaw   n  S_PROCEEDING          DID_ONHOOK
1/0/5         g711ulaw   n  S_PROCEEDING          DID_ONHOOK
1/0/6         -          -  -                                         DID_ONHOOK
acampbell
HI,
You need to know about what the service provider has configure their end of the DID trunks to use.
Under the voice ports on your router you should be able to try the 3 different flavours of DID signalling
voice-port x/x/x
signal did {immediate-start | wink-start | delay-start}
The most common usage is WINK-START
Alex
Regards, Alex. Please rate useful posts.
Thanks for helping....
All DID ports started out as immediate-start. Site could get inbound calls on immediate-start. Changed all DID ports to wink-start and site is still able to get inbound calls. Rebooted 2951 port 1/0/6 was wink-start and it getting static on port now when calling on it (see below) changed back to signal did immediate. Will reboot later tonight to see if issue comes back. Did a shut/no shut and that did not clear it out. All other ports are playing nice for now.
1/0/1         -          -  -                     DID_ONHOOK
1/0/4         -          -  -                     DID_ONHOOK
1/0/5         -          -  -                     DID_ONHOOK
1/0/6         g711ulaw   n  S_PROCEEDING          DID_ONHOOK
voice-port 1/0/0
signal did wink-start
timeouts call-disconnect 2
timeouts wait-release 2
description DID card
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
shutdown
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
description FXS DID card
voice-port 1/0/7
shutdown
ATT removed the bridge clips on the ports that were not releasing and the ports did not release. ATT also re-ran the new lines to 66 block.
ATT said points to Cisco phone equipment/configuration. I was looking over my configuration, can something here be changed?
voice translation-rule 2
rule 1 /\(.*\)/ /870777\1/
rule 2 /\(.*\)/ /870777\3/
voice translation-profile imcoming
translate called 2
voice-port 1/0/0
signal did immediate         <-- this has been set to signal did wink-start and both have failed
input gain 10
description DID 61.DINA.870-777-8646 D500
dial-peer voice 1 pots
translation-profile incoming imcoming     <-- can this be removed and
destination-pattern .T                            <-- be changed to 870777[1,3].. for DID range
no digit-strip                                         <-- do not know what else this could be
port 1/0/0
TAC debuged my calls & found after a DID call hunted my dial peers and did not see anything CUCM tried to send the call out the DID port. DID ports only take inbound calls. When tring to sent the call outbound a DID port is locked up the port.  Added "huntstop" on my last dial peer per TAC. No issues since!!!!!
dial-peer voice 14 voip
preference 1
destination-pattern XXXXXXXX..
session target ipv4:XX.X.XXX.XXX
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 15 voip
preference 2
voice-class h323 1
codec g711ulaw
no vad
dial-peer voice 16 voip
huntstop   <-------------------------------------------
preference 3
voice-class h323 1
codec g711ulaw
no vad
