24 Lines on FXO ?? HELP !!!
Gezimvatovci
I have c3945 voice bundle platform, i'm looking to connect 24 lines on Router.
c3945 can support only 3FXO all 12 ports but i need to connect 24 ??
If i want to use E1 card like HWIC-1CE1T1-PRI how to connect all those lines on E1, one side is RJ45 other side ??
do i need to use any converter how to connect all lines ??  what kind of cable to use from E1 module to those lines. ?
Please find me a solution to connect all 24 analog lines on c3945.
 analog lines ----- > c3945 ----- > phones
 Thanks a lot,
GV
2 Accepted Solutions
Terry Cheema
Yes it will support 60 (3945-E) or 64 FXO (3945)
Ref: http://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/series-comparison.html
Models Comparison
4451-X
3945E
3925E
3945
3925
2951
2921
2911
2901
1941 / 1941W
1921
Form Factor
2 rack units (RU)
3 rack units (RU)
3 RU
3 RU
3 RU
2 RU
2 RU
2 RU
1 RU
2 RU
1 RU
Maximum voice support for analog and Basic Rate Interface (BRI)
Planned
Foreign exchange station (FXS): 108
Foreign exchange office (FXO): 60 BRI: 38
FXS: 60
FXO: 36
BRI: 22
FXS 112, FXO 64, BRI 40
FXS 64, FXO 40, BRI 24
FXS 40, FXO 28, BRI 16
FXS 16, FXO 16, BRI 8
You will need to use EM-HDA-6FXO cards. Refer to below post for details:
https://supportforums.cisco.com/discussion/11379681/can-single-cisco-router-can-accomadate-32-fxo-ports
-Terry
Please rate all helpful posts
FXO and FXS use the RJ-11 connector. FXO is used for termintaing lines coming from your Telco. The phones will terminate on switch, connected to the router. If you are asking you want to plug phones as well on same router them you will need switch module (but that may limit the number of FXO ports due to space it will take.
Ref: http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/nm/hardware/installation/guide/eesm_hw.html#wp1143505
Let me know if you have more questions
-Terry
6 Replies 6
Terry Cheema
Models Comparison
4451-X
3945E
3925E
3945
3925
2951
2921
2911
2901
1941 / 1941W
1921
Form Factor
2 rack units (RU)
3 rack units (RU)
3 RU
3 RU
3 RU
2 RU
2 RU
2 RU
1 RU
2 RU
1 RU
Planned
FXS: 60
FXO: 36
BRI: 22
-Terry
Thanks a lot for solution Em-hda-6fxo
But what kind of cable is use for this module?
From EM-HDA-6FXO to analog wires?
Thanks.
Gv
Venperun,
this EM-HDA-6FXO card need to connect with cable on black box or any patch panel ??
what kind of cable do I need to use to connect EM-HDA-6FXO with thous wires from Telco. Black box ?? any patch panel ?? what cable ?? Thanks, GV
PSTN telco lines ----> (    ?    ) -------> c3945 --------> switch ---- > ip-phones
Thnx,
GV
-Terry
Terry this EM-HDA-6FXO card need to connect with cable on black box or any patch panel ?? what kind of cable do i need to use to connect EM-HDA-6FXO with thous wires from Telco. Black box ?? any patch panel ?? what cable ?? Thanks, GV
