28XX router support CM 10?
Chi Fai Leung
I know the 28XX will be EOL on 2016. And I want to upgrade the CM version to 10.
I want to check out the 28XX router support the SRST on CM 10 version?
I checked the compatibility guide just mentioned support CM 8.6. As the command, callmanager fallback 7+  <--- That mean after the 7 version, the SRST is no more update features? So that should be support on CM 10 with 28XX VG SRST?
Or
I  should check the IOS (12.X) version only on CM 10?
Hi Leung,
28XX Series support upto SRST version 8.6 which in turn supports cucm 9.0 and 10.0.
This questions was answered before: SRST and CUCM 9.1
Also check: Cisco Unified SRST 8.6 Supported Firmware, Platforms, Memory, and Voice Products
Also Doc: ISR G1 SRST compatibiity questions answered here!
Best of Luck/Happy Holidays!!!
