2950 Voice Config with CME
amarley270
I am setting up a lab for my CCNA Voice with a 2950XL Switch running 12.0(5,2) and a 1700 running CME on 12.4-15.
Everything works fine if I run the switch with no config, ie default settings
However as soon as I enter any Voice config the phones stop working and just show "Configuring IP"
I have two vlans configured vlan 100 for data and vlan 200 for voice
The ports are configured as
"Switchport mode access
switchport access vlan 100
switchport voice vlan 200"
This does not work but if I remove this and the enter
Switchport access vlan 200
This does work, for the phones at least
What am I doing wrong ?
Thanks, Andrew.
5 Replies 5
acampbell
Hi Andrew,
Can you share the configs of the 2950 and the 1700.
If you are going to run a data & voip vlans you will
need to trunk switch to router and providedjcp for both vlans
Regard
Alex
Regards, Alex. Please rate useful posts.
In addition to what Alexander said, please check phone is assigned expected voice VLAN through CDP and broadcasting DHCP in correct VLAN....
Thanks for the responses guys,
Config is attached, this is with just the "switchport access vlan 200"
configured in which case the phone on port 17 works and the one on port 20 doesnt
This is what I would expect, however with the config detailed in the OP it still doesnt work.
Obviously I would like this to work with the Voice and Data Vlans but am trying with just the voice vlan to see if it makes troubleshooting easier so with one vlan would it require trunking ?
If I change the ports (9 and 17) tp
Phones stay on "configuring IP"
Hi Andrew,
Can you change the set up between the switch & router.
We need to make sure we have created the vlans and trunk the switch port to the router a trunk.
On the switch
vtp mode transparent
vlan 100
name DATA
vlan 200
name VOICE
int fas 0/9
shut
desc *** TRUNK LINK TO 1700 CME ROUTER ***
no switchport access vlan 200
switchport mode trunk
switchport trunk allowed vlan 100,200
no shut
! YOU can now define you phone ports to be dual vlan DATA/VOICE
int fas 0/17
shut
desc *** DATA & VOICE PORT ***
switchport mode access
spanning-tree portfast
no shut
On the router we define interface fast 0/0 with 802.1q sub interfaces
and create a dhcp scope for your data vlan
Please replace with your own subnets/addresses
ip dhcp excluded-address 10.10.100.1 10.10.100.10
ip dhcp pool DATA
   network 10.10.100.0 255.255.255.0
   default-router 10.10.100.1
router ospf 100
 network 10.10.100.0 0.0.0.255 area 0
int fas0/0
shut
no ip address 192.168.0.6 255.255.255.0
desc *** TRUNK & ROUTE PORT TO 2950 ***
no shut
int fas0/0.100
desc *** DATA VLAN ***
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
no shut
int fas0/0.200
encapsulation dot1Q 200
no shut
THEN TEST
Hope this helps
Reagrds
Alex
acampbell
Hi Andrew,
If the switch is from the 2900XL ranges these a really old & End of Life
You configure the vlans and vtp mode differently.
You do not use conf t to build the vlans - you use exec mode only
Then conf t for the interfaces etc
switch#vlan data
vtp transparent
vlan 100 name DATA
vlan 200 name VOICE
exit
conf t
interface FastEthernet0/17
shut
switchport trunk native vlan 100
no shut
int fas 0/9
shut
no shut
Alex
