.323 gateway and CUCM call hand up delay and call s
ausjustin
I've got a very vexing issue.  I converted a router over from MGCP to h.323.  IOS Advanced IP Services 152.4M6  With MGCP to H323
there was never an issue :
1.       Intermittent call drop outs
2.       Inbound calls call hang up / call termination / end call delay issue around 30 second delay
Justin
10 Replies 10
Hi Justin.
Can you please send us the actual config of your H323 VG?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Attached
Hi Justin.
Thanks for the configuration.
Can you also please send a show controller E1 and a debug isdn q931 during an incoming call with a termination delay?
Carlo
Thanks Carlo
PBX-3925-02#
Sep  3 09:47:54.537: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00FC
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18382
                Preferred, Channel 2
        Calling Party Number i = 0x2183, '63451244'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '94556667'
                Plan:ISDN, Type:Subscriber(local)
Sep  3 09:47:54.537: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x80FC callID = 0x099F switch = primary-net5 interface = User
PBX-3925-02#
Sep  3 09:47:54.541: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80FC
        Channel ID i = 0xA98382
                Exclusive, Channel 2
Sep  3 09:47:54.757: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80FC
PBX-3925-02#
Sep  3 09:47:55.781: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80FC
Sep  3 09:47:55.797: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00FC
PBX-3925-02#
Sep  3 09:48:03.245: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x9151
        Cause i = 0x8A9F - Normal, unspecified
        Progress Ind i = 0x8488 - In-band info or appropriate now available
PBX-3925-02#
Sep  3 09:48:08.921: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x00FA
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep  3 09:48:08.921: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x99D
Hi Justin.
From this debug I can see that the call has been disconnected immediately.
Can you confirm it?
please also add these to commands in your config
voice call disc-pi-off
voice call convert-discpi-to-prog
Let me know
Carlo
I already add on  voice call disc-pi-off .
but what's the "voice call convert-discpi-to-prog"  for ?
and also do you think we remove the " service mcid" will help ?
dial-peer voice 1 pots
 description **** Inbound Calls****
 service mcid
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
HI Justin
That could help
Regarding voice call convert-discpi-to-prog is to change the diconnect message to progress in order to try to send the call status to the CUCM when a disconnect arrives from PSTN
Carlo
thanks a lot .
and also maybe I will try change this above timer  "param mcid-release-timer" to 10 seconds instead of 30seconds and then see whether now the calls disconnect after 10seconds, which confirms that the issue is with MCID.
Yes.
Also try that and pleas let me know
Carlo
