IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hi Cisco techs,Cant get my Cisco 7912 phone to ring. Has IP address and switch/router can ping each otherDial peers are configured. Same as DID and ports. Using CME 3.3.Have DID number from a VSP. Test call to number goes straight to voicemail after ...
We are setting up a 10 channel E1 R2 in Brasilia. Its currently working perfectly with a PBX, we are moving it to CME with 2811We are in the testing stage, I am testing it remotely from Europe which isnt ideal.Currently, the E1 comes up and inbound c...
keanej by Level 3
  • 443 Views
  • 1 replies
Resolved! CME Ios
hi alli use gns3 to build simulation for my CCNA Voice my question is that should i insert CME Ios to Router?or one of the Enterprise IOS that router has sufficient and support full voice ?
zavira123 by Level 1
  • 1285 Views
  • 9 replies
  Hi,I want to take serial numbers of all phones for call manager 8.6. I tried "Netpacket-cucm-phone-audit-tool" but it is valid for cucm 9.x version.Can anyone tell me how same tool can be used for cucm 8.6 ? Also I tried, "serial grabber" but it is...
HelloI have a issue with BLF.Below is the scenario, when the manager login (UDP) in the phone on secretary's phone BLF doesn't work, when manager and secretary both  logout the BLF works Manager    EXTPartitionCSS  111InternalLandline  111GSMInternat...
