3725/3845 Router
dtom
We have two questions:
1) Does CallManager 10.5/11.0 support the 3725 router (voice gateway)?
2) Does CallManager 10.5/11.0 support the 3845 router (voice gateway)?
6 Replies 6
Jaime Valencia
I'll assume you mean for MGCP, just checked on 11, they both show up
java
if this helps, please rate
When you say "show up", do you mean:
Add a new Gateway | Gateway Type
Yes
java
how about 11.5?
That version has not even FCSed, if you want info for a version that is not yet publicly available, you'll have to get it via your AM/SE.
java
ok thanks
