3rd Party SIP phone registration failed with CUCM over Internet
shaibal.n
I have been struggling to register an Android based 3rd Party SIP phone(BRIA) over the internet with my Lab CUCM 8.6 from the last two weeks but unable to make it registered in the CUCM.
I can see the traffic is hitting in the GSN3 Router also SDI logs proves that phone keeps try to register but no positive outcome.
By the way I am doing it totally IP based communication where no DNS is involved.
My Public IP : 117.194.99.29
Traffic coming from mobile : 223.231.63.190
CUCM Inside local IP : 172.16.50.90 [Natted with 117.194.99.29 on tcp and udp port 5060]
Call manager Hostname : CUCM-PRI
SIP Extension : 20005
Phone Security Profile in Place [Third-party SIP Device Basic Security Profile with Digest Authentication Checked]
Standard SIP Profile is also in place.
Below are the sample SDI logs from CUCM for reference.Can you please help me to sort this out
16:10:20.964 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 675 from 223.231.63.190:[42557]:
[14719,NET]
REGISTER sip:117.194.99.29 SIP/2.0
Via: SIP/2.0/UDP 100.76.75.173:46897;branch=z9hG4bK-524287-1---5f6e015a19defa02;rport
Max-Forwards: 70
Contact: <sip:20005@100.76.75.173:46897;rinstance=f6aa5510a0999417>;+sip.instance="<urn:uuid:a5be4cb6-8bd6-57cc-bb46-efed48d015b7>";reg-id=1
To: "Rahul Dravid"<sip:20005@117.194.99.29>
From: "Rahul Dravid"<sip:20005@172.16.50.90>;tag=0dee664b
Call-ID: 134557_rel38ZGE5MDUzYThhOWM0OTUxZTUwNzA3MTIyYmI5YjJkODI
CSeq: 1 REGISTER
Expires: 900
Allow: INVITE, ACK, CANCEL, BYE, REFER, INFO, NOTIFY, OPTIONS, UPDATE, PRACK, SUBSCRIBE, MESSAGE
Supported: outbound, path
User-Agent: Bria Android 3.6.4 build 89377
Content-Length: 0
|1,100,230,1.11039^223.231.63.190^*
[14720,NET]
Max-Forwards: 70
CSeq: 1 REGISTER
Expires: 900
Content-Length: 0
|1,100,230,1.11040^223.231.63.190^*
16:10:20.965 |//SIP/SIPHandler/ccbId=911/scbId=0/findDevicePID: Routed to SIPStationInit|1,100,230,1.11039^223.231.63.190^*
16:10:20.965 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11039^223.231.63.190^*
16:10:20.965 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb3f42080|*^*^*
16:10:20.965 |EnvProcessUdpPort::fireSignal - SEND, destination = 223.231.63.190:46897|*^*^*
16:10:20.966 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 377, 223.231.63.190:46897)|*^*^*
16:10:20.966 |CMSIPUtility: isIPAddrOrHostInMyCluster no match found for 117.194.99.29 in the cluster host/ip cache|*^*^*
16:10:20.966 |CMSIPUtility::isOurTopLevelDomain TLD is and host is 117.194.99.29|*^*^*
16:10:20.966 |CMSIPUtility::isOurClusterFQDNName TLD is and host is 117.194.99.29|*^*^*
16:10:20.966 |CMSIPUtility: isMyIpAddrOrMyHostName Node ip or host name did not match 117.194.99.29 |*^*^*
16:10:20.966 |SIPStationInit: Failed to find host, fabricating FQDN: CUCM-PRI.117.194.99.29|1,100,230,1.11039^223.231.63.190^*
16:10:20.966 |CMSIPUtility: isIPAddrOrHostInMyCluster no match found for CUCM-PRI.117.194.99.29 in the cluster host/ip cache|*^*^*
16:10:20.966 |CMSIPUtility::isOurTopLevelDomain TLD is and host is CUCM-PRI.117.194.99.29|*^*^*
16:10:20.966 |CMSIPUtility::isOurClusterFQDNName TLD is and host is CUCM-PRI.117.194.99.29|*^*^*
16:10:20.966 |CMSIPUtility: isMyIpAddrOrMyHostName Node ip or host name did not match CUCM-PRI.117.194.99.29 |*^*^*
16:10:20.966 |SIPStationInit: Rejecting foreign host/domain in request uri: sip:117.194.99.29|1,100,230,1.11039^223.231.63.190^*
16:10:20.967 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,230,1.11039^223.231.63.190^*
16:10:20.967 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,230,1.11039^223.231.63.190^*
16:10:20.967 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11040^223.231.63.190^*
16:10:20.967 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb3f42080|*^*^*
16:10:20.967 |EnvProcessUdpPort::fireSignal - SEND, destination = 223.231.63.190:46897|*^*^*
16:10:20.967 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 392, 223.231.63.190:46897)|*^*^*
16:10:20.967 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11039^223.231.63.190^*
16:10:20.967 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 458, 223.231.63.190:46897)|*^*^*
16:10:21.245 |EnvProcessUdpHandler::handle_input - handle = 331|*^*^*
16:10:21.245 |EnvProcessUdpHandler::handle_input Status: 0, Id: 0|*^*^*
16:10:21.245 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 675 from 223.231.63.190:[42557]:
[14724,NET]
Max-Forwards: 70
CSeq: 1 REGISTER
Expires: 900
Content-Length: 0
|1,100,230,1.11041^223.231.63.190^*
16:10:21.246 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11041^223.231.63.190^*
16:10:21.246 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb3f42080|*^*^*
16:10:21.246 |EnvProcessUdpPort::fireSignal - SEND, destination = 223.231.63.190:46897|*^*^*
16:10:21.247 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 458, 223.231.63.190:46897)|*^*^*
16:10:23.249 |EnvProcessUdpHandler::handle_input - handle = 331|*^*^*
16:10:23.249 |EnvProcessUdpHandler::handle_input Status: 0, Id: 0|*^*^*
16:10:23.250 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 675 from 223.231.63.190:[42557]:
[14726,NET]
Max-Forwards: 70
CSeq: 1 REGISTER
Expires: 900
Content-Length: 0
|1,100,230,1.11042^223.231.63.190^*
16:10:23.251 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11042^223.231.63.190^*
16:10:23.251 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb3f42080|*^*^*
16:10:23.251 |EnvProcessUdpPort::fireSignal - SEND, destination = 223.231.63.190:46897|*^*^*
16:10:23.251 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 458, 223.231.63.190:46897)|*^*^*
16:10:28.340 |EnvProcessUdpHandler::handle_input - handle = 331|*^*^*
16:10:28.340 |SdiStats: #Lines: 46 Free HWM: 21 Free HWM(total): 261|*^*^*
16:10:28.340 |EnvProcessUdpHandler::handle_input Status: 0, Id: 0|*^*^*
16:10:28.340 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 675 from 223.231.63.190:[42557]:
[14728,NET]
Max-Forwards: 70
CSeq: 1 REGISTER
Expires: 900
Content-Length: 0
|1,100,230,1.11043^223.231.63.190^*
16:10:28.346 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|1,100,230,1.11043^223.231.63.190^*
16:10:28.346 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb3f42080|*^*^*
16:10:28.346 |EnvProcessUdpPort::fireSignal - SEND, destination = 223.231.63.190:46897|*^*^*
16:10:28.347 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 458, 223.231.63.190:46897)|*^*^*
16:10:29.417 |//SIP/SIPTcp/wait_SdlReadRsp: SdlRead bufferLen=20|1,100,63,1.1340^223.231.63.190^*
16:10:29.418 |//SIP/SIPTcp/wait_SdlReadRsp: Saving 420 bytes of incomplete message data.|1,100,63,1.1340^223.231.63.190^*
16:10:29.418 |//SIP/SIPTcp/cleanupConnection: Unprocessed SIP data at connection close, device = , connIdx = 69, data:
shaibal.n
Just to add, I have no issue using the xlite windows based 3rd Party SIP phone to register it from LAN Setup.
