12-26-2012 12:33 AM - edited 03-16-2019 02:52 PM
Hi Team,
One of my customer needs to change thier existing 4 digit extension number to 5 digit because future expansion. i was trying to use the Bulk administration tool but no luck.
please advice.
Ashraf
12-26-2012 12:58 AM
Hi Ashraf,
BAT is the right way to do it. You would need to export the dialplan, modify it and then import it back.
Harmit.
12-26-2012 01:00 AM
Hi Harmit,
But we have to delete all existing details.
Ashraf
12-26-2012 01:04 AM
Hi Ashraf,
Yes you would probably need to do that. The other possibility is you can create translation patterns and retain the 4 digit extensions as they are. Add the new extensions as the 5 digit extensions. Not sure if that is an option for you or not, but worth a try.
Harmit.
12-26-2012 01:08 AM
Hi Harmit,
Translation pattern will do, but customer wants to change the extension no.
I read some where that we can do SQl query and update in the database, not sure its TAC supported.
Ashraf
12-26-2012 01:24 AM
Hi Ashraf,
Thats right, it would not be TAC supported. BAT is the TAC supported method.
HTH.
Harmit.
12-26-2012 07:57 AM
I have done couple of such migrations, and this is not a trivial effort as besides DNs on the phones you need to consider the following:
change forwarding destination for DNs that are currently setup for call forward
change DNs on CTI RP, CTI Ports if you have any
change voicemail profile, voicemail pilot, hunt pilot(s), route pattern(s)
change translation patterns if appropriate
change meetMe, call park, pickup groups, etc if needed
adjust GW configuration if needed (i.e. dial peers)
if you have other apps such as UCCX, change the jtapi triggers (need to delete and rebuild), review all scripts to ensure there are no references to old DNs, etc
If you have voicemail, change the DNs on voicemail, change DNs of call handlers, etc, caller input destinations on call handlers, etc
So, as you can see it is essential to review the system for all possible required changes, document them, schedule outage when you can reconfigure the system in order to make sure you complete it successfully.
HTH, please rate all useful posts!
Chris
12-27-2012 12:05 AM
Hi Chris,
Have you tried VG224 and VG248 as well?
Ashraf
12-27-2012 07:39 AM
Sure, VG248 is SCCP so there is nothing on the GW itself that you need to change, only DNs in CUCM of the SCCP endpoints. With VG224 it comes down to which protocol you are using, if SCCP or MGCP same as VG248. If using SIP or H323 then you'll need to adjust dial-peers and route patterns on CUCM.
Chris
12-27-2012 10:39 AM
Chris is spot on (+5 C.D.), the most important thing here is that you make yourself aware of all of the dependencies related to changing your abbreviated dialing solution. Especially if you went the path of programming station lines, etc. with the abbreviated numbers (vs. a normalized or globalized strategy).
Chris' list is pretty comprehensive on where you should look to prepare for a change like this. The process or tactics you use to execute the changes depends on various factors. The most important factor being the comfort level of your staff, yourself, or your consultant (whichever one applies). The change is tricky. It would be most ideal to leverage a resource that has experience navigating these changes to avoid negative service impact.
From a CUCM perspectice, you could use BAT export/import. This method may be more "approachable" for someone who isn't comfy under the hood of the CUCM. However, it is a bit "bloated" from a process perspective and you will be doing some clean up.
Yes, it is true you can also use SQL to tackle this change. This can be a more streamlined approach but comes with a fair amount of risk for the uninitiated. Whenever I have to make broad changes in CUCM I use SQL. With proper application, it is a good tool for making sweeping changes quickly and with minimal (if any) impact to other aspects of your call processing. However, I can't stress enough how improper application can screw up a lot of things. Also, there are few people that know the ins and outs of the DB. I know because I have behind a few folks who meant well but executed poorly.
My recommendation to colleagues who are tackling this type of change goes the path that Chris has forshadowed:
1. Prepare: Make sure you understand all of the moving parts in your entire solution (not just UCM and not just station DNs). Again, Chris' off the cuff list is a great start for info gathering.
2. Plan: This starts with a strategy. Go via BAT or via SQL. If you don't have the experience in-house and can't or don't want to hire someone who does, then you might be better off going the BAT path. SQL is cleaner when you know what you are doing but a disaster if you don't (or don't have a way to test, see #3). Once you pick your strategy, then map out the plan details. Map out every step of execution as well as a roll back strategy if you happen to screw something up.
3. Practice: If you have a lower environment for testing (e.g. a lab or lower environment production system) then you are in a great position. If you don't then you may want to stand up a vm environment just to test out your process on UCM. Yes, testing all systems is ideal but most of the meat is in UCM and if you can test on a VM then that is better than nothing. The point of practicing is to gain confidence and reduce risk.
If you (or one of your teammates) are comfy with SQL then you may find some useful information here:
http://www.ucguerrilla.com/search/label/CUCM%20SQL%20Query
I have some blog entries that cover most of what you would need to look at but only one or two actually tackle the question of doing bulk updates. So, it may be a good way to get ideas but only if you are inclined to go that path and have some comfort with SQL databases.
-Bill (http://ucguerrilla.com)
12-30-2012 11:40 PM
Hi Chris,
In the existing setup all the vg224 are configured as SCCP, so how did you export the analog endpoint details?
Ashraf
