40 seconds delay via CUBE
kaysplace
Hi Everyone,
I am currently having up 40 sec delay making outbound calls via my Cube.
haven't gone through several solutions on the forum still did not work.
I have adjusted the T302timer from 15000 to 5000 still did not work and have also check both my dial peers and Route pattern on both Cube and CUCM still not working.
Anyone with working solution should please help out.
Thanking you in Anticipation.
Jaime Valencia
Start by reviewing CUCM traces and debugs to find out if your delay is due to overlapping dial plan in CUCM or your CUBE, or something in your network is introducing delay, or if it's your telco.
java
if this helps, please rate
