ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
5.1.3 database replication problem on Cisco Unified Reporting window
esinyener
We are trying to replace the hardware of our pub+sub. We installed the publisher and the subcriber respectively,and then upload the backup file taken from the production publisher.
Although the Replication states seem as 2 on RTMT , we can not see the cluster node's IP addresson CCM Reporting window.
Has anyone ever seen a situation like that? What can be done to solve this problem?
smalkeric
Level 6
Level 6
Check this bug for changing the node address of the callmanager cluster:CSCsj20487
Actually we are not trying to make any ip address change. We have new hardwares for both pub and sub. we are installing them on a seperate test environment with the same IP address with our production servers.
